cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
how do i write my own MIB in SNMP?
I want to write my own MIB for the automatic meter reading..how do i start with it..?
Santosh Chavan
IIT MADRAS.
0 kudos
Mensaje 1 de 6
3.974 Vistas
A great place to start is with this KB: http://digital.ni.com/public.nsf/websearch/4CD3625A939A77DE852564050047D3BD?OpenDocument.  You also might want to continue to search the NI site for examples with the TCP/IP protocol, and see if anyone else has worked with SNMP.
For example:
http://forums.ni.com/ni/board/message?board.id=170&message.id=162952&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=159350&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=164931&requireLogin=False
Thanks for posting!  Good luck, and let us know if you have any other questions!
Travis M
LabVIEW R&D
0 kudos
Mensaje 2 de 6
3.959 Vistas
Thanks travis,
 i will definitely get back to youu if i have any doubts...
thanks again..
Santosh Chavan
IIT MADRAS.
0 kudos
Mensaje 3 de 6
3.948 Vistas
Travis,
 i want to write my own MIB for energy metering purpose. I have SNMP toolkit for labview . I want to get started with MIB .  I just want to know how do i start with it. I know what are the parametes to be defined.
Santosh Chavan
IIT MADRAS.
0 kudos
Mensaje 4 de 6
3.937 Vistas
Hi Santosh -
The best references to get started with the SNMP Toolkit is through the documentation/manual/examples provided by the developers of the toolkit.
Here is a link to the reference manual for the  SNMP Toolkit Manual.
I've searched through the NI databases, and we don't have any examples available for the SNMP Toolkit.  I would contact SNMP Toolkit Technical Support with specific support questions regarding this toolkit.
Hopefully, someone with some experience using this SNMP Toolkit might be able to provide some insight on configuring the applications.
Mark Walters
Application Engineer
0 kudos
Mensaje 5 de 6
3.917 Vistas
Thanks mark,
  hey u keep on ur serach . if u find something on it then please forward it me.
Santosh Chavan
IIT MADRAS.
0 kudos
Mensaje 6 de 6
3.908 Vistas
