how do i run a vi i created in windows version labview in the mac version labview?
I have created a VI in the windows-version of LabVIEW. I want to be able to run this in the MAC version. Is this possible without purchasing the MAC version of LABVIEW?
Message 1 of 8
(3,496 Views)
No.
Message 2 of 8
(3,491 Views)
The VIs themselves can generally be transferred between platforms, but you'll need the correct version of LabVIEW to open and run them.
Jeff | LabVIEW Software Engineer
Message 3 of 8
(3,471 Views)
If they were only stand-alone vis that i wanted to run, would that be easier to use between the platforms?
Message 4 of 8
(3,454 Views)
What do you mean by stand alone VIs?
There are certain functions that are not cross-platform compatible. They include the .NET and ActiveX functions. The windows only function are marked as such in the on-line help. Certain hardware functions are windows only. This would include DAQmx. If you use that, you need to convert to DAQmx Base.
Message 5 of 8
(3,452 Views)
By stand-alone I mean that i have made my vis into .exe files.
Message 6 of 8
(3,399 Views)
If you build an exe on a windows platform, you can run it only on a windows platform. The only cross-platform support is with the source code and you must have the MAC version of LabVIEW in order to load the source code.
Message 7 of 8
(3,396 Views)
Message 8 of 8
(3,392 Views)
