how do i prevent the default 0(if for example) from passing forward?
how do i prevent the default 0(in the case structure for example) from passing forward? (i.e. don't wanna see 0s in my output files)
(2,356 Views)
cn_tower;
You need to provide more information. Better if you can provide the code for review.
You can always delete a case from the case structure. Right-click on the case and select "Delete case".
Regards;
Enrique
www.vartortech.com
(2,356 Views)
