OH! Quite easier than you think!
On the front panel display of the sub VI you will see the icon.
Right Click - Show Connector
Simply pick a pattern, click the terminal, and then click the actual indicator on the front panel. (many recommend using the wiring tool while doing this)
That fix you up?
Chances are if you have seen VI in the forest it hasn't fallen.
