how do I synchronize parallel while loops?
I was wondering how can I synchronize the execution of my while loops? I already implemented the parallel connection of error cluster in the two loops but still the code executes either one of the loop first before the other. how can i eliminate the delay in between the loops?
labview - pulse generator
Attached here in my post is the copy of my code.
(14,756 Views)
Hi ralvarez,
The conntinous acquisition part runs parallel in your code - every while loop runs in a separate thread provided that you don't implement dependencies (maybe your Pulse generation VI isn't set to reentrant? --> attention: Raise conditions) of the two loops.
HTH
Joachim
Message Edited by Joachim082 on 05-14-2008 07:08 AM
(14,752 Views)
Two DAQmx Tasks accessing the same resources cannot run in parallel.  They have to take turns running.  I would reduce the DAQmx to one task and have your code that you want to run in parallel in the same loop.  You didn't attach one of your vis so my image has them missing, but this will run the way you want, I think, as long as the one vi that you didn't attach is set as reentrant.
Randall Pursley
(14,716 Views)
I already did what Randall has suggested but the vi inside the while loop has timing vi inside it. The purpose of the two period and non-zero variables is to set different pulse lengths on the two channels (see attached picture). My problem with the previous one is that I cannot synchronize the pulses. In what was suggested, the loop waits for the vi that has a longer delay and this does not meet the results that should be expected. I already included here the other vi.
Thank you for your help!
(14,673 Views)
Accepted by topic author ralvarez
Will this do what you want?
Randall Pursley
(14,644 Views)
Hi Randall,
Thanks! Your code works. Smiley Happy
(14,595 Views)
