how delete the special rows of array string
how i can delete  string's rows that have &&KK, in this array?
Message 1 of 11
(3,738 Views)
  1. Wire string data into a for loop
  2. Use Match pattern inside the array to detect &&KK and use conditional indexing to output just the elements that don't have &KK
Message 2 of 11
(3,731 Views)
plz more explain, i want to delete the rows including &&kk,
Message 3 of 11
(3,696 Views)
What don't you understand?  You were told exactly what to do.  What have you tried?
You use a FOR loop to go through each element of your array.  Use Match Pattern to do the check for &&kk in the string.  If it was not found autoindex that value out.  The conditional indexing is very useful here.
GCentral
Message 4 of 11
(3,687 Views)
i try it, but it dont work
Message 5 of 11
(3,665 Views)
Post your code. It will help us help you.
In what way is it not working?
Message 6 of 11
(3,661 Views)
Also please next time don't attach a 6MB VI containing a sample array with almost 100k elements. A sample array with 20 elements would be sufficient to show the problem.
Message 7 of 11
(3,639 Views)
He posted in LabVIEW 6.1, which does not have any conditional indexing.
Still there are plenty of threads here that show how to filter a 1D array ... 😉
Message 8 of 11
(3,632 Views)
Good observation on the 6.1. I guess marii will have to
  • Create a shift register with an empty array of strings.
  • Go through each element in String Data and  search for &&KK using match pattern
  • Use a case structure to either append the String Data element to the shift register or leave the shift register as is.
  • Create an indicator from the output of the loop's shift register
Whew, I guess I know why NI added the conditional tunnels.
Message 9 of 11
(3,621 Views)
I did notice that after I made that post.  That will indeed make things more interesting.
OpenG has some good examples of how to filter an array.
GCentral
Message 10 of 11
(3,603 Views)
