取消
显示结果
搜索替代
您的意思是:
how connect matlab-simulink with labview interface
hi, i need to your help, i have a simulink file and i export to matlab some variables, with these variables y need to show in a waveform chart, but i dont know how to do this connection, i didnt find how to do, only olds methods, please i need help
0 项奖励
1 条消息(共 2 条)
2,715 次查看
Hi  jorgedu94.
You can use the MATLAB script node in LabVIEW to run your scripts or load variables from your .mat files. Here's a community example that shows how to do just that:
https://forums.ni.com/ni/attachments/ni/170/490598/1/testfile.zip
And this is the forum where the example came from:
https://forums.ni.com/t5/LabVIEW/how-to-load-a-variable-using-MATLAB-Script/td-p/1109577?profile.lan...
Hope you find this useful.
0 项奖励
2 条消息(共 2 条)
2,680 次查看
