how can we input and update numeric control in front panel when a fast while loop is running?
Dear all,
In my code, I have a while loop doing fast grabbing (sampling)
how can I update other numeric controls in the front panel when the while loop is running?
right now, once I input a number into this numeric control, the computer seems to be no response at ell. it looks like computer is focusing on the while loop.
any ideas are appreciated.
thanks
jack
Message Edited by igg_integrin on 02-26-2009 02:38 PM
Message Edited by igg_integrin on 02-26-2009 02:39 PM
Message 1 of 15
(5,563 Views)
Are you sure the program is in the while loop?  The code below has a very fast while loop and the control updates fine.
I'm inclined to believe your program calls a program inside the while loop that is looping indefinitely, thus holding up the calling while loop.
Please clarify/post the code in question.
Tim Elsey
Certified LabVIEW Architect
Message 2 of 15
(5,552 Views)
Posting your code would be very helpful - or at least a screen shot. Otherwise we are basically shooting in the dark.
Mike...
LabVIEW Champion
Message 3 of 15
(5,532 Views)
And are you sure the data is actually changing?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 4 of 15
(5,517 Views)
thank you all for your reply
here is my code
one while loop is to processing the image grabbing..
the other one is to reponse the event to change the numeric control's value
every time when I input the numeric 1, the code seems stop..no response at all.
is it becuase the way I code two while loops in parallelll isn't correct?
thanks
Jack
Message Edited by igg_integrin on 02-26-2009 11:11 PM
Message 5 of 15
(5,502 Views)
Try putting a 0ms wait timer in the top loop.  It may be running so fast that it never allows the other loop time to execute.  What does Windows Task Manager say your CPU usage is?
Message 6 of 15
(5,500 Views)
thanks
Jack
Hi Jack,
Please see here.
Your parallel placing of while loops may not be a problem at all for LV, but only the non-availability of any small loop delay inside the top loop.
Also, please check your CPU usage, eventhough if it is a dual core PC, as Ravens Fan has suggested.
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 15
(5,484 Views)
Hi Jack,
Try using Timed Loop ,where u can set the prority and which loop to run in which processor.
check out this link
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/creating-deterministic-applicatio...
Rgds,
Venky
Message 8 of 15
(5,454 Views)
Why do you need this fast update rate. Your LCD computer screen has a update rate around 60Hz. Movies are usually filmed at a rate of 24 frames per second.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 9 of 15
(5,420 Views)
thank you all,
finally I found a way to solve it..
jack
Message 10 of 15
(5,395 Views)
