how can we force to use a specific locale in data formating?
Hi all,
  I am using the Format Date/Time String to format the current date to a formatted string, I am specify %b to show the abbreviated month but that parameter depends on the locale in the host computer. Is that any way to force the format on a given locale instead of using the OS's locale? Thanks.
(2,872 Views)
Accepted by topic author dragondriver
I don't believe so. The simplest solution would be to call the DateTime to Seconds function, extract the resulting month value from the cluster and then use a look-up table to determine the month name.
The look-up table could be as simple as a multiline string that is indexed with the Pick Line function using the month as the line index.
(2,852 Views)
Thanks. I follow the way you suggested.
(2,837 Views)
