how can i separate 2(most significant digit ) from dingits like 200258,2001f4,2000Bc so on
hi
how can i can separate 2 (most significant digit) form digits like 200258 ,2001F4, 2000BC or of form 2XXXXX.i am getting output of this form where most significant digit 2 singnifies sign and rest gives the value of output(hexadecimal digits).
thank you
naveen
(2,453 Views)
Use the logical AND function. 200000 AND 2001F4 = 200000. To get the value section use 1FFFFF AND 2001F4 = 1F4. These logic functions accept numeric inputs and perform bit-wise logic functions on the arguments.
If I recall your earlier post correctly the next two bits after the sign bit determine the decimal point location. So the data value mask should be 7FFFF rather than 1FFFFF.
Lynn
(2,449 Views)
