how can i run case structure programitically
hi,
i am working on a vi , which has stages from 0...5. i am trying run the program, so that it executes case 0...5 one after other. and if i want to stop the program in the middle of the process, how i can connect the "stop" button to all cases, so that they all stops at the same time.
Could you pls help me ..
Message 1 of 9
(3,883 Views)
use a state machine there are tons of examples on this forum.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 9
(3,880 Views)
here is an example:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 3 of 9
(3,876 Views)
make sure you put a delay in the while loop:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 9
(3,874 Views)
Hi Sandy,
Use a boolean shift register in which the stop button state can be updated and the same can be used as the case selector to select whether to run or not to run the forthcoming cases. So that the program will come out of the cases immediately without any delay and stop thence.
MRK (CLAD)
Message 5 of 9
(3,869 Views)
If all five states always execute in sequence, you could also do something similar to the following. (assuming you have a newer LV version that alllows for the conditional terminal in FOR loops)
Use shift registers to hand data from one state to the next if needed.
Message Edited by altenbach on 05-31-2009 09:59 PM
Message 6 of 9
(3,865 Views)
HI  ,
Thank you so much for the solution.
As i am new to labview, i am trying to log all outputs of my vi.
that is , i want to display the outputs of each case structure as it executes.
Could you pls help me to do this.
Thank you.
Message 7 of 9
(3,797 Views)
Try something as follows:
Message 8 of 9
(3,786 Views)
Is this ok?
MRK (CLAD)
Message 9 of 9
(3,784 Views)
