how can i export my FFT vibration data to excel using write to spreadsheet file.vi
Hai guys
I wonder if anyone could help me on how can I  export my FFT vibration (waveform) data into excel using write to spreadsheet. Vi and how can I read it back from excel into labview using read from spreadsheet file.vi ?
Thank you
(4,385 Views)
See attached file
(4,354 Views)
i'm using LV 8.6 and i cant find the array you use between the for loop and transpose 2d array, may i know what its called
(4,336 Views)
That is Build Array.
Actually, that transpose array isn't even needed if a True boolean is wired to the Transpose? input of the Write to Spreadsheet File.
Message Edited by Ravens Fan on 01-13-2010 11:50 PM
(4,332 Views)
