i am attempting to delay the execution of a case structure as a funtion time that is calculated via two controls on the front panel. i have tried using the hardware clock and using comparitors to provide a true/false comand to a case structure but is there any way to cause the case structure to be true in incremints of some time and remain true from some other time and then return false.
thanks for the help
