how can i convert an ascii character to a number?
where can I find the function?
Message 1 of 8
(4,537 Views)
Message Edited by mathan on 06-27-2008 01:33 AM
Message 2 of 8
(4,536 Views)
no use
Message 3 of 8
(4,528 Views)
Hi roverboy,
when it's only one char you can use "typecast" to convert to an U8 number. Or you take "string to U8 array" and pick the first element...
Message 4 of 8
(4,522 Views)
A string will be converted to an array of U8.
Unless you convert a single character.
RayR
Message Edited by JoeLabView on 06-27-2008 05:39 PM
Message 5 of 8
(4,490 Views)
Well, yur question is not clear at all, for example if the ASCII character is 0..9, it already IS a number! 🙂
You need to define what kind of number you want. A typical use would be to convert it to the U8 number that has the same bit pattern as the character. In this cas you would typecast it to a U8. Anyway, from your question it is not clear what you need, so please be more specific.
Give an example!
If the ASCII charcter is "1", should the output be decimal 1 or 49? BIg difference, but both could be correct depending on what you actually want.
Message 6 of 8
(4,477 Views)
thanks all people here ,the question are solved,the good method is  JoeLabView's  and GerdW 's.
Message 7 of 8
(4,442 Views)
Glad to help.
Message 8 of 8
(4,435 Views)
