how can i connect labview with ge fanuc versamax plc via VISA
I, ve a ge fanuc versamax plc. I am building a data logger in labview. There are two current trasmitters. I dont have any other data acquisition devices other than PLC. How can i access data acquired by PLC and how can i connect it with labview using VISA?
(5,072 Views)
What interface to the PLC do you have? Serial? If you have an RS-232 interface then you can simply use the VISA Write and Read functions in LabVIEW to communicate with the PLC. You will probably want to check documentation for the PLC to learn about what API it provides for communicating through whatever interface it has available.
Repost if you have further questions or more details.
Best Regards,
JLS
Best,
JLS
Sixclear
(5,050 Views)
@KPAC wrote:
I've a ge fanuc versamax plc. I am building a data logger in labview. There are two current trasmitters. I dont have any other data acquisition devices other than PLC. How can i access data acquired by PLC and how can i connect it with labview using VISA?
There may be variations between models, but I believe all VersaMax support Modbus and GE's own SNP/SNPX serial communication protocols.
For Modbus communication protocol:
The link here is a good outline of the different options available. If you really want to limit yourself to the option of using VISA, then it's Items 1. and 2. in Khalid's list that are applicable. You might have to modify some of the free LabVIEW Modbus VIs to suit you needs, but they are useful as examples if you have little experience programming a serial driver.
For SNP/SNPX:
Your options are similar to those for Modbus, except that I'm not aware of any existing free set of LabVIEW VI's for it. With a web search you might find something (I almost programmed one 10 years ago). The SNP/SNPX protocol is/was well documented in a GE FANUC manual which you could get from them (in 1993 it was GFK-052B "Series 90 PLC Serial Communications User's Manual") so you still can write your own set of VIs.
If you don't really need to limit yourself to using VISA, there are ActiveX and OPC drivers available which use SNP/SNPX that you can find with a web search. And you can see here that NI's Industrial Automation OPC Server's do include an object for GE Fanuc Versamax via Ethernet. This would not be the cheapest in terms of capital cost though.
Good luck.
Fading out. " ... J. Arthur Rank on gong."
(5,045 Views)
We are using serial interface. It has SNP protocol. I dont have much idea about how to access plc from labview.
I,ve tried VISA read/write functions. If u can, tell me in detail wat i,ve to do for getting that transmitter values scanned by plc. How can i convert the string Acquired using VISA into useful information to use with my labview program?
(5,044 Views)
