how can i change the daqmx properties without entering my block diagram
Level - beginner.
Hai,
Currently I’m doing a research using Labview to create a VI to be use for a condition monitoring front panel. The problem is that I need to enter my block diagram (to the DAQmx/daq assistant) each time if I need to change my input channel, sensitivity and other as well. How can I change all the parameters without entering the block diagram, only to change in the front panel.
Example, i'm Using AI Accelerometer, how can i change the units, sensitivity, etc. from my front panel and not entering the block diagram to have it change on the daqmx itself.
My idea is to have a front panel as i attached 'wanted' which i found i one of the example in labview. any help and idea will be much appreciate.
cheers, hafiz.
(2,666 Views)
Hi hafiz,
 Place respective controls on the front panel including the physical channels
 Thanks and regards,
srikrishnaNF
Srikrishna
(2,642 Views)
