how can i automatically maximize lab view project (if project is minimized) if no one is working on PC after one time
where is "get foreground window" and "set foreground window" in labview 2016?
Message 21 of 38
(1,212 Views)
Hi Asif,
as you apparently read Blokk's link you should have seen this part of the text:
Solution: If you use the functions GetForegroundWindow and SetForegroundWindow in the User32.dll located in C:\WINDOWS\system32, the Front Panel is set in front of all desktop windows.
These are CLF nodes ("Call Library Function")…
Message 22 of 38
(1,210 Views)
really i dont know how to do that.
i can see user32.dll file in that location.but how to use it as that snip..
Message 23 of 38
(1,206 Views)
I do not want to be mean or anything, but you could really try to do some effort, and use google search, LabVIEW help, LabVIEW tutorials, etc... 😉
http://zone.ni.com/reference/en-XX/help/371361P-01/glang/call_library_function/
Message 24 of 38
(1,202 Views)
I tried the official NI example VI, it does not work for me. I have also found this: http://www.labvolution.com/labview-making-a-window-active/
Neither works. I have no time to experiment with these codes now, I might test more later...
Message 26 of 38
(1,184 Views)
Accepted by topic author Asif138
Actually this example works, I had a typo only: http://www.labvolution.com/labview-making-a-window-active/
Download the example VI, and set the name input the same as the VI's name: "Window to Front.vi".
Here is a snippet too (I also attached the example VI):
Message 27 of 38
(1,180 Views)
it is working, but some time it automatically maximized but not be on top of all window.
Message 28 of 38
(1,154 Views)
For me my example VI works 100%. Can you reproduce the problem, and attach your VI or snippet? How often it does not come to foremost, top of all windows?
Message 29 of 38
(1,151 Views)
i am running same your VI in my PC..
Message 30 of 38
(1,138 Views)
