03-20-2006 02:18 PM
03-20-2006 02:37 PM - edited 03-20-2006 02:37 PM
Message Edited by Enrique on 03-20-2006 03:37 PM
03-20-2006 02:40 PM
You cannot OR a boolean with a number. ![]()
You need to capture the system time when you start the loop and add your wait time to that value to give you a "finish" time.
Then as you loop compare the current time to the "finish" time and when the current is greater than the finish, you will have a second TRUE Boolean that can be used to stop the loop.
03-20-2006 02:41 PM
03-20-2006 02:54 PM
03-20-2006 03:19 PM
03-20-2006 03:32 PM - edited 03-20-2006 03:32 PM
No. When you compare two numbers, you get a number out. Look at and read the function help. Try this. The function I used is Elapsed Time. Somehow the label got mangled when I pasted it into paint.
Message Edited by Dennis Knutson on 03-20-200602:35 PM
03-20-2006 03:34 PM
03-20-2006 03:37 PM - edited 03-20-2006 03:37 PM
Message Edited by Warren Massey on 03-20-200601:38 PM
