how can I stop a while loop
In the program in attachment I want that when I stop loop 1, sequence 1 or loop 2 also stop. Do you know what I should do? Thanks
Message 1 of 18
(5,139 Views)
You probably want to write 'TRUE' to a 'Value' property node of the STOP button in loop2 from loop1. To do that you will need to change this STOP button's mechanical action from 'LATCH' to any of the 'SWITCH' options.
Please let me know wether it helps, or whether you need an example
Message 2 of 18
(5,132 Views)
Hi Aurelia,
I modified a bit your VI and added a few comments, to explain how it works.
If you need further help, fell free !
Epictetus
Antoine Chalons
Message 3 of 18
(5,119 Views)
Here is a way to do it with just one stop button.
- tbob
Inventor of the WORM Global
Message 4 of 18
(5,103 Views)
You cannot stop the sequence, it must complete on its own. (One of the reasons sequencees should be used sparingly. They are rearely needed)
You can use a single stop button and use a local variable of it in the second loop. Another nice method is the use of event structures. You can capture the stop event on all other loops as shown in the attached example (LabVIEW 7.0).
Message 5 of 18
(5,102 Views)
Thank you very much. Could you please save the vi in the version 7.0. I do not have 7.1. Thanks again
Message 6 of 18
(5,091 Views)
Message 7 of 18
(5,091 Views)
My example is in Version 7.0 🙂
Message 8 of 18
(5,088 Views)
Thank you very much. I made some changes to loop MOD. In loop 2 there is a continue if true linked to a true / false. I need loop 2 to stop when I stop loop1. However, I have a message error for event structure and event data node. Do you know what I did wrong? Thanks again
Message 9 of 18
(5,082 Views)
I forgot to attach the vi
Message 10 of 18
(4,990 Views)
