how can I rename a file programmatically?
@teky wrote:
Can i change the target path of a file and rename it in the same MOVE.VI?
I don't see why not. Did you try it?
___________________
Try to take over the world!
Message 11 of 14
(1,424 Views)
ya it works.  I had a problem with it, but i was using a vi to list files and folders, then i used the list as a path, so it only gave me a relative path instead of an absolute.  i was using that path for my target.  so i had to use change up some things to get the full path.  works though!
Message 12 of 14
(1,418 Views)
i have a question...
i have automattically created pdf files using PDFcreator and created autosave to pdf.
i was able to rename my pdf files to serial number that it was supprose to be..but i am stuck on a situation...
i have SN_11111.xls, SN_11112.xls, SN_111113.xls in a directory..
how would i rename all directory files under *.xls to
*.pdf??????
Please help...
thank you in advance...
Krispiekream
Message 13 of 14
(1,161 Views)
okay..i got...
use the  search and replace string function to search for .xls and replace with.pdf
Krispiekream
Message 14 of 14
(1,159 Views)
