how can I pass cal kit data from file to 8510A?
Hi
My device is  8510A network analyzer.
I have some cal kit files which I download them from Agilent.
How can I pass the data from file ( that is from pc) to 8510A?
what command should I use?
for example, "INPUCALK" command used for Input Cal Kit for 8720 series NA.
May you help me?
thanks
yasamin
(2,354 Views)
@yasmain62 wrote:
Hi
May you help me?
thanks
yasamin
How is this a LabVIEW problem?
If you don't understand how an instrument works, contact the manufacturer or read the manual.
(2,328 Views)
I will post my problem in Agilent Forums.
thanks
yasamin
(2,297 Views)
