how can I open the .sif file generated by andor solis
Hi guys, I am working with an imaging measurement using Andor's EMCCD. It is generating files in the format of .sif.
I am making a labview based analysis software but labview doesnt open .sif file direcly. I am wondering how I can open this crazy .sif file using labview direcly?
It is basically a stack of multiple images files with some head files.
Message 1 of 9
(9,367 Views)
Hi Shuohuang,
I think what you need is this DataPlugin http://zone.ni.com/devzone/cda/epd/p/id/5955
This should allow LabVIEW to support SoMat Information Files (SIF).
Kind regards,
James W
Controls Systems Engineer
STFC
Message 2 of 9
(9,341 Views)
Thanks so much. I will get it a try very soon. The patch that Andor technical support provided is just very poor. Hope this one solves the problem
Message 3 of 9
(9,338 Views)
Hi James:
I have downloaded the data plugin and installed it. however, still dont know how to read the .sif file into labview.
It is basically an image stack file which I would prefer to load it into labview as 2d data arrays
Message 4 of 9
(9,320 Views)
Hi Shuohuang,
You normally open image files in LabVIEW in a way similar to this:
http://digital.ni.com/public.nsf/allkb/02971A30F5D8FC6986256A0A004F11A0
Or you can import them if they are one of these file types
http://digital.ni.com/public.nsf/websearch/DD7B2734795BDAF386256BE40067B6A0?OpenDocument:
I've never dealt with .sif files before and you say that it is a stack of multiple images so I'm not sure how the normal image functions will work with .sif files.
If you can post one of the files on here then I can have a play and see if I can figure out how we open them in LabVIEW.
James W
STFC
Message 5 of 9
(9,299 Views)
There is a utility from andor that reads sif files.  I think that it comes with Solis.  I find it at program files\Andor Solis\Drivers\SIF Reader .
Message 6 of 9
(9,292 Views)
By "utility", I mean a set of Labview wrappered just wrappered dll functions.  If you don't have it on your install, I am sure that Andor would provide it to you.
Message 7 of 9
(9,287 Views)
I am using LabWindows/CVI. Can you teach me how to open Andor .sif file using SIF.uri?
Message 8 of 9
(7,147 Views)
I have never used labwindows/CVI, unfortunately.  Andor almost certainly has some examples in the install location that I referenced above.  You should have a look at those and then just steal the code that does what you need (that is what I did).  Not sure if this helps.  Also, you might be able to get andor to autosave your data to a file format that you are more familiar with?  J
Message 9 of 9
(7,141 Views)
