how can I increment the index of an array in a formula node?
I need some help with the formula node. I need an array, that increment every iteration of the code in the formula node. I need it to save amplitudes.
I thought i could do this with i++; i is the variable for my index.
Martin
(4,135 Views)
Hi Martin,
can you please explain a bit more what you need?
Maybe the attached picture can help you.
Mike
(4,129 Views)
Hi  Mike,
I need cases with diffrent conditions and in every case  instead of the conditions it should generate a new amplitude for a extern Diode. The Diode send Infrared singnals for testing IR-Receiver.  Some timtes I need the older amplitudes because I must find the smallest singnal on that the receiver can geht enough pulses. So in every case the index must be step up an save in this array element the new amplitude.
I hope I explained well.
Martin
(4,126 Views)
does it sound well to you ?
Tinnitus
ps: sorry posts mixed
Message Edité par tinnitus le 12-15-2008 03:05 AM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(4,121 Views)
Can you put the formula in a for-loop and wire the "I" as input?
I'm not sure what you're after but that'd change the ingoing variable.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,088 Views)
Accepted by topic author ernstm
Hi Martin,
why do you use the formula node for it?
Mike
(4,073 Views)
it's true for simple operation why don't you use diag block?
but may be its a little part of what you make ?
an exemple here:
Tinnitus
(4,063 Views)
