how can I get a continous graph of a motor count versus intensity even if the motor stops
I had a motor to rotate a mirror and the detector detects the position of spot and stop the motor if it is not equal to a particular value .The problem is that, when the motor stops the graph goes back to zero in X axiz . So how can I get a continous graph without going back to zero in X or Y axis. I'am posting the VI which I made please help me with some advice or corrected snippets
(2,382 Views)
Along with VI send data.. what time what you want.
It will be better to help then
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,368 Views)
