how can I expand an array by interpolating between adjacent elements in the array?
Hi
I would like to expand my array by interpolating between adjacent elements (this is for a data smoothing application of a 2d data set)
I have split my 2-d array into two 1-d arrays.  With one of the 1-d arrays I would like to interpolate between adjacent elements to expand it.
e.g. for the array 1.0, 2.0, 3.0, 4.0, 5.0
I might want  to expand to: 1.0, 1.5, 2.0, 2.5, 3.0, 3.5, 4.0, 4.5, 5.0.
alternatively does anybody know of a smoothing VI for 2-d data?
Many thanks
Ash
(3,086 Views)
Hi Ash
I attached a small example (it uses the Interpolate 1D Array VI). Be careful, the attached VI is inefficient if the input array is long. In this case it might be better to create an array with the final length (input size*2 -1), wire it to the shift register and replace elements inside the loop instead of inserting into the input array.
For 2D-arrays, just put another for loop with auto-indexing around the code.
Daniel
(3,076 Views)
Hi Dan
Many thanks
Worked a treat on my data!
Ash
(3,060 Views)
