how can I do cluster with both indicators and controls
I make a program with lots of variables, and I want to group them in clusters to reduce the number of variables in my diagram. I notice that we can't make clusters with both indicators and controls. Is somebody know how to make clusters with both types of variable or know an other solution to gather variables?
thank you
Message 1 of 17
(3,837 Views)
Well, it makes even more variables, but you can use a Read Local Variable of indicators to cluster them.
2006 Ultimate LabVIEW G-eek.
Message 2 of 17
(3,837 Views)
You should be able to create a cluster to meet your needs. I am able to create a cluster and wire controls and values that I pass to an indicator.
I am not sure what you mean by not being able to wire an indicator... You are right in the sense that an indicator receives a value, but does not pass it to something else like a cluster. But you should be able to wire the value going to the indicator to the cluster (in parallel).
Attached is an example of what I describe above. Hope it helps.
JLV
Message 3 of 17
(3,837 Views)
Yes,
This is a good example..
Message 4 of 17
(3,837 Views)
Also a good example! 🙂
Go data flow go.
~j5
Message 5 of 17
(3,837 Views)
In additional, sometimes you need to combine in one cluster controls and indicators for user interface purposes. Theoretically you cannot to do this, but with small modification you can... See in attachment (modified Jonnie 5's example)
Message 6 of 17
(3,837 Views)
Thank you very much everybody for your answers and examples?
Andrey you have done what I want to do but I don't understand how do you do that!
when I put an Indicator in a cluster it became control. What is your "small modification"?
Message 7 of 17
(3,837 Views)
the item you called indicator in the cluster is a control which seems indicator. Are you customized the control?
Message 8 of 17
(3,741 Views)
The indicator in the cluster is not really an indicator. It's a control with the increment/decrement not shown (possible in LV7), or either colored transparent or resized (possible with control editor). All that has been done is to change the appearance. You cannot mix controls and indicators in a cluster.
Message 9 of 17
(3,838 Views)
Hurrey,
I'm sure fcheritel is happy with all these answers but Dennis is absolutely true.
What would happen to the cluster if it had Controls and Indicators in it ??
I still gonna give a **** to everyone for the help on this.
Julien
Message 10 of 17
(3,838 Views)
