how can I create a executable vi in Linux?
I have my vi, and I want to create the executable file. But I want to run this program (vi) in a embebeded PC that works over Linux!!so , I dont have screen and I dont want the panel up. How can I do this? Is it an option when I compile my vi and build my aplication?
Thank you!!!
Graci
(2,961 Views)
Hi Graci,
Currently LabVIEW for Linux requires an X server. You can accomplish this by running a dummy X server on your embedded Linux PC. Or, you can install only the X libraries and then set the display to another networked X server.
You might be aware that NI has several Real Time products that might suit your needs well. You can use PXI for the equivalent of a PC, or fieldpoint if you need a smaller/embedded solution, or RT plug-in boards which are basically PCs on a PCI card. All of these options would allow you to run LabVIEW executables "headless."
Your project sounds interesting, let us know more about it and it's requirements!
David Duffey
(2,960 Views)
