how can I convert 1D array into 2D array labview
Hello everyone,
I want convert 1D array into 2D array, My array included only one  boolean Value..
BR
(4,921 Views)
Hi
wire the 1D array to a build array function and you will get a 2D array
btw, what is it that you are trying to achieve?
Regards
Freelance_LV
TestAutomation Consultant
(4,920 Views)
Hello, Thank you for your asnwer... what I am  doing.. at first I have array and I tested this array if it is empty with array Size funktion.. If array size ist not Zero (!=0) so I get the value true .. und I put this true in a new array ( So I used here build array). so I get array but as 1D  but  what I need is  this array as 2D...should I change the option with Build array, so that I have 2D ?
(4,907 Views)
ok..
if you want to check if the array is empty, use the Empty Array function in Comparison palette!! 🙂
Regards
Freelance_LV
(4,903 Views)
you can use empty array function to check whether array is empty or not.
But that output why you want in 2Darray?
any specific requirement?
(4,893 Views)
