hold plot in graph
Hi
is there a way in a labview waveform graph to hold a plot (similar to
matlabs hold on)?
I'm looking for an easy way to plot sampled data after receiving a graph
window - without erasing the old plot. And, of course, to erase all old
plots with a click. Only way I found is to save all the data in an extra
array with extra wiring effort to erase all....
Regards Wolfgang
(4,975 Views)
Actually the graphs in LV are not just the pictures. They are the arrays of data which represent some curve. So plots on the grath are saved in memory as a 2D array of numbers where each row corresponds to some plot. From this point of view
1. To add graph to plot you have to add some row to this 2D array.
2. To remove graph from plot you have to delete some row from 2D array.
3. To erase graph you have to erase the 2D array. This can be done by replacing of it with empty array.
4. To draw new plots you have to replace this 2D array with another one.
I've written an example which performs these three operations. But I didn't take care about colors of plots so when you delete some plot you will see that colors will be shifted. I think that it can be so
lved using graph properties responsible for plot colors.
Good luck.
Oleg Chutko.
(4,975 Views)
