hold button dynamic array
I have a 1-D array, that store the samples from a dynamic sine waveform, so the value of the array elements are changing all the time.
What I would like to do is to have like a hold button, so to store to values of the array at a specific time,like when i push the hold button, and then the stored array values ​​to be displayed on a waveform graph.
Thanks in advance for your time
(2,802 Views)
Accepted by topic author mxflorin
Hi mxflorin,
sounds like you need to use a case structure. Put the graph inside the case structure and use a latching button...
(2,798 Views)
Thanks GerdW, it`s working.
(2,793 Views)
