hoe to check, table is empty or not
i have to check table before entring it wheter it is empty or not
Message 1 of 9
(4,016 Views)
Just connect Empty Array , available in comparison palatte.
Message 2 of 9
(4,013 Views)
Compare the terminal to an empty 2D array constant
_____________________________
- Cheers, Ed
Message 3 of 9
(4,005 Views)
thanks for reply,,,
 i have another problem,, if i call one vi and after running this vi, how to close called vi and come back to calling vi with refrence to the  called vi,,
thank you
Message 4 of 9
(3,987 Views)
In the VI properties of the second VI (ctrl-I), in the window appearance section, check the show front panel and close afterwards boxes.
In the application control palette, you can use the 'This VI' reference and wire it to an output from the VI to return it to the calling VI.
- Cheers, Ed
Message 5 of 9
(3,983 Views)
Message Edited by Phillip Brooks on 11-17-2008 08:23 AM
Message 6 of 9
(3,979 Views)
Thanks for reply;;
as per my knowledge ,in vi property only available is "close afterwords original closed". so it will close only after calling program get closed, is it correct?
 and using of refrence i am not getting can please help with some examples
Message 7 of 9
(3,976 Views)
This will open and display the Sub VI, then close it again and return its refnum to the calling VI
Message Edited by yenknip on 11-17-2008 01:44 PM
- Cheers, Ed
Message 8 of 9
(3,963 Views)
how to read the text file line by line in LabVIEW 8.0
Message 9 of 9
(3,926 Views)
