hide front panel when opened
I have a VI running as a back ground task (VI_A) to the main VI (VI_B). VI_B starts VI_A and the idea is that VI_A will be minimised on startup. There is a button on VI_B to restore the window and a button on VI_A to hide the window and return to VI_B.
This is all working OK, I open VI_A front panel when called, VI_B minimises VI_A straight away etc, I am using the WINUTIL.LLB functions to perform this. The problem I have is VI_A front panel is visible upon start up for a couple of seconds (there is no real delay in my execution to minimise). I have tried setting VI_A to be at teh back within VI_A but still it appears at the front for a couple of seconds.
Does anyone have any suggestions as to why this is occuring.
Cheers,
Wayne
(2,986 Views)
One thing that you could do is to change the Windows Appearance property to NOT open front panel when called. You can then have your main VI (VI_B) open the panel for VI_A as before, but it will not start with the panel open. If you are creating an executable, go to the VI Settings tab page and click on the line with VI_A and then Edit Settings. Turn OFF the Remove Panel property. This should work for you (I've done similar already anyway).
Rob
(2,986 Views)
