hide front panel bars at open
Good morning,
Is there a way that I can hide the FP title bar and menu bar etc… at open? From the VI Properties, I can hide them at run time. But I would like to hide them at Open. I have a running main vi, it opens and runs another vi(code is attached). The main vi is run with full screen and hiding title, menu bar etc… I need to have the secondary vi run full screen without the bars as well. If I make changes in VI properties setting, the bars will disappear at run time, but I can see the bars flashing before they disappear. Any idea on how to accomplish this?  Thank you for your help and time!
Yonghe
(2,606 Views)
Accepted by topic author a2h
What I would do, if I'm understanding you correctly, is don't show the window when you call the VI (this can be set in VI properties; uncheck the box to show front panel when called). Then, in your code, set the windows properties using property nodes and after they are set programmatically show the window using a property/invoke node.
(2,589 Views)
Thank you very much for your help! I finally get it to work. As you suggested, I have properties settings done in program, and also run vi before FP.OPEN.
(2,553 Views)
Not a problem, glad you got it all figured out!
(2,540 Views)
