hi
hi
 i designed a system thats detect some parameter of ECG signals using LABVIEW 8.2 then i found that FPGA kit ( ordering code of FPGA is : DK-DSP-3C120N ) thats i want to use is not compatible with any version of labview
how can i solve this problem ?
and how i can change the design to software accepted to this kit at least time
thank you
(2,690 Views)
also discussed here.
(2,681 Views)
Well... you should consider the following:
1.  How much (extra) time and effort will it take to provide a solution using the existing kit, versus using one that is supported.
2.  What software and API's support the existing kit (you should contact the supplier).
3.  How familiar are you with Labview versus the software that supports the existing kit.
R
(2,679 Views)
