hi
i have real &imaginary values sperated by comma . each 2 values represent 1 point i want to get magnitude and phase of each point individually??
ex.  23,46 (represent one point as 23+46i)
       10,12(as 10+12i)
thanks
Message 1 of 18
(4,695 Views)
Where are you having problems?  Can you not get the Real and Imaginary parts out?  Having trouble calculating the Magnitude and Phase?  Show us what you have tried and good representation of the data you are receiving.
Message 2 of 18
(4,683 Views)
This?
Jim
Message 3 of 18
(4,664 Views)
1.00373363495E+00,-2.81245142221E-01,-2.47617978603E-02,-1.17851829529E+00
1.00373363495E+00    is real of first point
-2.81245142221E-01    is imaginary of first point
i want to identify this as one point?
 i want to get magnitude and phase of this point to draw it?
Message 4 of 18
(4,663 Views)
As mentioned in your other thread, please give less useless titles for threads, and not "hi" or the like.
Tim Elsey
Certified LabVIEW Architect
Message 5 of 18
(4,648 Views)
As with his other thread, no attempt to write any code. Freeloading, I suppose.
Message 6 of 18
(4,646 Views)
I would start with the Spreadsheet String to Array (found in the String pallet) with a comma as the delimeter to create a 1D array of strings.  From there, convert all of the strings into numbers, reshape the array into a 2D array (each row should contain 2 items).  Then you can use a simple for loop with autoindexing and there's a nice primitive in the Numeric->Complex pallet to convert from Real/Imaginary into Polar form.  Give it a try.  If you get stuck, show us how far you made it and what part you can't figure out.
Message 7 of 18
(4,629 Views)
A descriptive title also makes it likely that you will get valid results from the search you must make before you post.  Unless you're too lazy to look through them of course. Smiley Sad
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 8 of 18
(4,620 Views)
Try this...
Message 9 of 18
(4,590 Views)
I convert to 2D array.
now, how i can make it real and imaginary ??
26+49i
81+93i
thats what i want to get ?
Message 10 of 18
(4,534 Views)
