hex to binary
Hey all,
I am trying to convert a 16 bit hex word to binary (I need a string of 1's and 0's in such a format that I can do a value check on each bit individually). I am getting the hex value in as a string (if I want to display the hex value to a string indicator, I have to set the indicator to "hex" display mode, otherwise it just comes out as a bunch of weird characters.....ASCII?).
I am sure this is probably pretty simple, but I can't seem to get it right. Thanks in advance for your help.
Paul
(4,241 Views)
This thread may be of use to you:
http://forums.ni.com/ni/board/message?board.id=170&message.id=159169&query.id=56353#M159169
(4,236 Views)
Just typecast your string to U16, display it in a numeric indicator, and change the display to binary format with 16 digits padded with zeroes on the left.
(Optionally, you can convert it to a boolean array (using "number to boolean array") and display the bits as such).
(4,235 Views)
Here's a quick example (LabVIEW 8.0) showing some possibilities. Maybe one is suitable for your situation. 😉
(4,227 Views)
I think that is exactly what I need. Thanks for the help!
Paul
(4,191 Views)
