hex character into columns
Hi, I am trying to go from ascii characters to Hex. It works fine. but I need my hex numbers to show in 4 columns ( as show on this text file, how can I do that?
Message 1 of 9
(4,016 Views)
Four columns on your front panel string display?  Then just resize your string indicator so it is only wide enough to show 4 bytes across.
Or do you want this to show in a text file?  Then convert the string to a byte array.  Resphape the array from a 1-D to a 2-D.  Convert to hexadecimal characters.  Then use the 2-D input for strings for Write to Spreadsheet file to output to a text file.
Message 2 of 9
(4,000 Views)
Ravens Fan beat me to it. But here it is in code.
LabVIEW 2012
Message 3 of 9
(3,989 Views)
Thanks, but it looks like I cannot get the all thing.
Message 4 of 9
(3,987 Views)
Oh! Thanks, I didn't see this last reply yet.
Message 5 of 9
(3,985 Views)
You misunderstood what Ravens Fan said. He told you to simply resize the front panel string indicator, not to chop up the string in code.
To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
Message 6 of 9
(3,978 Views)
For the non-Regex-impaired and those who dislike padding with zeros.
Message 7 of 9
(3,977 Views)
Regular expressions are much more clear after they have been compiled to machine code.
Spoiler
Just kidding. They only look confusing if you are not familiar with them. They really do make sense after you learn them and are very powerful!
LabVIEW 2012
Message 8 of 9
(3,968 Views)
Thanks a lot, both are giving me what I needed.
Message 9 of 9
(3,941 Views)
