help with this vi
I am trying to make a manual for an application i wrote in labview i tried using the URL vi but was unsuccessful its tells me that the file could not be found even though my path was correct also i have looked at making a custom menu and I can not figure out how use the help with this vi or the help files * I don’t know if either of these will help me make a help menu so if anyone can help i would greatly appreciate it.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,040 Views)
How you ensure that your path was correct?
"Unsuccessful" - That's not enough to predict the problem.
Please post what you have did so far or just an image of the block.
Mathan
(3,012 Views)
very true i will post a sample code of what i am trying to do:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,005 Views)
Accepted by topic author Harold_Timmis
Try to convert your string to path before send it to the sub-vi.
The problem should be the space characters (see help).
Also you can open the sub vi and use it's sub vi
(2,988 Views)
Hi Harold,
The following KnowledgeBase Article should help you in creating a custom run-time menu:
http://digital.ni.com/public.nsf/allkb/17803AA31C8C07C986256CFD0080D609?OpenDocument
(2,960 Views)
