help with my homework (urgent)
Coordinate machine control (X, Y) with labview Unit 4 Design and construction of mechatronic systems based on microcontroller objective Design, construct and program a coordinate machine (X and Y axis) controlled through an interface in labview. Specific objectives Programming in a microcontroller the control of a coordinate machine. From a user interface programmed in Labview, send the X and Y coordinates to which the microcontroller must move the system. For both axes, the HOME function must be implemented. Tasks to do Implement the step-by-step engines with their respective power stages. Implement the end-of-stroke sensors for the HOME function of each axis. Develop the user interface in Labview. Develop the programming of the microcontroller to control the two axes of the coordinate machine; The coordinates will be received through the UART module. Through the user interface, the student can send the coordinate X and Y separately or in the same data frame. Specifications It is necessary that the two motors, power stages and end-of-stroke sensors are physically implemented; Rails are not required.
(2,705 Views)
And the reason you're not doing your own homework is?
(2,686 Views)
Right now I am a bit busy with some urgent work at my own work place, but I am willing to do this project for you. Since I have time only in the night (and I REALLY like to sleep), I think about 1000 EUR would be a fair fee for my work. If you want, send me more details, and I give you my IBAN number 😉
If you want to get real and free help in this forum you should make some effort, and show us SPECIFIC problems by attaching your code plus we need more detailed hardware spec...No one will do a full school project for you for free...
(2,678 Views)
