help with html report!
I was looking for a way to create a report and I got this suggestion from the forum:
"Hi,
If you use HTML (for rtf it's basically the same), you can make a template
HTML file. For all the things that need to be replaced, you type a tag, e.g.
something like &time&, for the actual time.
In LabVIEW, you just open the file, and replace all tags with the proper
values. This doesn't work with sizing tables, where you need to (partially)
build the table in LabVIEW, then replace a table tag with the table string.
Wiebe."
I think this solution is going to work very good for me. However I dont have too much experience handling html docs (for example, how to replace the tags). Can anybody give me any other details or co
de examples? (I'm using LV 7.1), Thanks a lot!
(2,884 Views)
The question in the original thread is answered...
Wiebe.
"pacp" wrote in message
news:506500000008000000ABF80000-1079395200000@exchange.ni.com...
> from the forum:
> "Hi,
> template
> tag, e.g.
> proper
> (partially)
> string.
> Regards,
> Wiebe."
> I think this
> replace the tags). Can anybody give me any other details or code
(2,884 Views)
I got it, thank you very much!
(2,884 Views)
