help please
hi there
i am new for using labview
i have missing daq assistant from my software labview as show in the figure
how can i found this icon ?
help
(3,566 Views)
Accepted by topic author waleedabdurhman
Did you install DAQmx driver?
(3,562 Views)
No i just install the software
should i install it to run ?
(3,559 Views)
If you want to use DAQmx VIs, you need to install it. If you do not install it, you cannot use these VIs.
Here you can see the compatibility list: https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
So check what LabVIEW version you have, and install the latest DAQmx driver for it. Example: if you installed LabVIEW 2017, then install DAQmx 17.1
(3,544 Views)
