help needed in plotting XY graph
hi i have attached the vi and an image which you will require when you the run it.
thanks
Message 11 of 12
(493 Views)
HI farhan,
sorry for bothering you, but can you save only the 2d array with data in it. Use the "make current values default" option. I can´t run your vi, because i have currently not the IMAQ Toolkit installed.
Mike
Message 12 of 12
(482 Views)
