help me bad wire
Hi I would like to realize a sonor effect.
It's the chopper.
This is the scheme :
[URL=http://img170.imageshack.us/my.php?image=il1xs2.jpg][IMG]http://img170.imageshack.us/img170/9899/il1xs2.th.jpg[/IMG][/URL]
Thx
(3,652 Views)
You need to use the "Convert From Dynamic Data" function on the output from your express VI. Right-click on the wire coming out of the express VI and going into the bottom terminal of your "Add" function. Select "Insert->Signal Manipulation Palette->Convert From Dynamic Data". A dialog should pop up to select the type of data to generate. You probably want 1D array of scalars.
(3,645 Views)
thanks
(3,640 Views)
I'm sorry but my english is bad.
I have a problem, this Vi doens't work. I would like to realize an sonor effect which is describe in the last post.
Help me please.
This is the Vi
(3,588 Views)
I don't know what's the trouble.
This Vi is good but it doesn't work.
(3,551 Views)
Hi hammer313,
try amending your start conditions:
stereo
16 bits
44.1Khz
xseadog
(3,543 Views)
Hello thanks for your answer.
I already have choice my start conditions but the sound create whit "simulate waveform" overalys the first sound wheres it must multiply both!
I need help!
night night
(3,533 Views)
