help in modifying my LV program
I need help in modifying my LV 6i, PCI-MIO-16E-1 program. I did send an email to oleg, however no reply. So I hope the expert out there can help me and advise me. I have attached my lv for reference. My program allow me to turn on both LEDs with flashing. (real LEDs). Can anyone teach me how to program my LEDs to R turn on while IR is off, IR is on while R is off and both off. I really deperately need guidance, as I'm really bad in programming.
Thanks for all the help
(3,579 Views)
I think you need to explain in more details what the problem is, your description is confusing to me.
  1. What is the purpose of the cluster?
  2. Do you want the real LEDs to be controlled by the cluster on the FP?
  3. Are you just looking for a radio button implementation such that  clicking one boolean in the cluster turns off the other one?
  4. Do you want the LEDs automatically blink as follows ((1) R: ON, IR: OFF, (2) R: OFF, IR: ON, (3) both off, repeat)?
  5. something else?
Please provide additional information.
Message Edited by altenbach on 02-25-2006 10:14 AM
(3,573 Views)
Hi Altenbach,
Thanks for you reply. I try to answer all your query. If you still confuse, pls let me know. In fact, the main purpose is on point 3. Thanks so much for your help, really hope you can guide and adive me.
          No special purpose for the time being. Cause I was testing out when LEDs can be turn on and off manually or not
    2     Do you want the real LEDs to be controlled by the cluster on the FP?
          Sorry what is FP?
    3     Are you just looking for a radio button implementation such that  clicking one boolean in the cluster turns off the other one?
         No necessary.
    4    Do you want the LEDs automatically blink as follows ((1) R: ON, IR: OFF, (2) R: OFF, IR: ON, (3) both off, repeat)?
         Yes this is actually what I hope to achieve
     5.  something else?
          not at the moment
(3,556 Views)
@Doraemon wrote:
          Sorry what is FP?
FP: Front Panel, BD: Block Diagram... 😄
Sorry, I currently don't have access to LabVIEW, but this should be simple. Maybe I can look into it tomorrow.
(3,553 Views)
Thks so much. I'll be grateful  to you. I'm hoping to hear from you again.
(3,543 Views)
Hi altenbach,
Some amendment, for point 4:
The Leds don need to blink. Just ((1) R: ON, IR: OFF, (2) R: OFF, IR: ON, (3) both off, repeat)?  Thanks. Hopeful to hear fr you.
(3,514 Views)
I no longer have LabVIEW 6.0, so I cannot make an example. I also don't have any DAQ drivers installed. What do you need to write to the port to light a certain LED?
(3,500 Views)
