hello
HI,
Finally got my system readng in data correctly!! (yeah). I also logged the data and checked that it is reading in correctly. However when I tried to combine the outputs in a similar way it wouldn't let me do it. A ideas again (please!!!). Because I have to perform functions on the inputs and generate outputs If I set the input DAQ Assistant to continuous 1 sample at frequency 1000hz, will my system work? Also do the CDD (CONVERT TO DYNAMIC DATA) VI's effect the way the data is processed? It was suggested to use arrays but I am unsure how to do this.
Thanks.
http://forums.ni.com/attachments/ni/250/10290/1/FINAL1.vi
Message 1 of 1
(2,404 Views)
