has to type each character twice while supplying command in Open VISA test panel
has a set of commands to work witha system connected to the MS windows PC. when I trype the commands in Hyperterminal (with/without ) they are yielding the expected results.
in LabVIEW, to get the expected results I MUST has to type 'each character' in the command Twice(except blank space) in the Open VISA test panel (viWrite/viRead). If I give the command  is given the usual way(with each character typed only once), the result always is 'illegal command'.....the same works fine in the Hyperterminal.
(2,974 Views)
Helo Sudhakara,
Please post the VI or snippet
(2,954 Views)
I am just using the 'Open VISA test panel' launched from the MAX after it detected my COM port (connected device). there is NO VI i am using for this.
thnx
(2,944 Views)
What confused Ashwin is that you said "In LabVIEW". OK, so you're using the MAX test panel. There's one thing that's not clear. You said "when I trype the commands in Hyperterminal (with/without )". With/without what? How is your Hyperterminal session configured? Have you tried something like PortMon to see what's actually being sent from the serial port driver?
(2,938 Views)
(2,937 Views)
What I mean with/without is 'Echo Typed characters locally' in 'ASCII set-up' of Windows Hypercritical application. Infact, the though 'Open VISA test panel' is expecting double char of the command, it's actually sending to the I/O buffers cmd with single character(NI tool is removing the duplicated char).
thnx for all your comments.
(2,899 Views)
