has anyone used the fpga compile farm toolkit?
Hello all,
This is my very first post, I have been trolling these forums for about two months now.  I hope this is an okay board to post this question too.
My question is if anyone has any experience using the cFPGA compile farm utility, and if it is worth the expense?  The team I work for is getting ready to re-write a mojor peice of software that will be used on 15 C-Rios for a whole bunch of hardware control and data aquisition.  Needles to say we will be doing a fair ammount of compiling and we dont want to tie down our work machines with these tasks, and instead would like to have some older desktops grind it out.
Thank you so much for any feedback you can give.
(2,489 Views)
Hi Unavailable
As I am an Application Engineer and I work for National Instruments, I would like to make an I impartial advice, I will highly recommend you to install the FPGA compile farm toolkit on a computer and use it as evaluation software, that way you could try it yourself and have your own opinion of the toolkit.
I think that if you will have to run many compilations it might be a good inversion. But as I told you above it will be better to try it and decide for yourself.
Regards
Esteban R.
(2,453 Views)
