has a problem to open the file path
hi, the attachment is my vi. I want to open a file path and then read out the data from that path. But if you run it, you will find there is no file path dialog jump out and so that you can not use the file path. Anyone know how to let the dialog jump out so that I can choose the file to read the data. Thanks
(2,485 Views)
solved. Sorry to post it here
(2,477 Views)
