harmonics analyze
I did a FFT and I obtained a power spectrum. I would like to know the harmonics' frequencies. Are there a VI to do this ??
Thank you
Message 1 of 15
(7,055 Views)
Yes, try the "Harmonic Anayzer.vi", it's in the "Advanced ... Signal Processing ... Frequency Domain" palette. 🙂
Message Edited by altenbach on 07-13-2005 09:22 AM
Message 2 of 15
(7,048 Views)
Theortically, for a single frequency waveform, you should have 1 peak at the fundamenmtal frequency.  If the signal contains harmonics, you should also see peaks at the harmonic frequencies.
You can also use the
Harmonic Distortion Analyzer.vi
Message 3 of 15
(7,046 Views)
Yes, I used harmonic analyzer. But I have a problem. On the graphe, my fundamental frequency is 500 Hz but in the option "detected fundamental frequency", I have 0,1705. Are there adjustments to do ????
Thank you
Message 4 of 15
(7,034 Views)
I tried an other thing. I used the VI "harmonic analyzer" for a signal sinus, and I have the good fundamental frequency. But with a spectrum, it doesn't work ? I don't understand why ?
Thank you
Message 5 of 15
(7,022 Views)
You may want to attach your code for examination.
Message 6 of 15
(7,023 Views)
Message 7 of 15
(7,017 Views)
The signal input to the harmonic distortion analyzer.vi   is the time domain signal.
in your example, attach the signal out of the   "formula waveform .vi" directly to the   signal in   of the  harmonic distortion analyzer.vi  .   (not the output of the FFT)
Message 8 of 15
(7,015 Views)
Ok.
But If I want to know the frequencies of my fundamental frequency and my harmonics, how must I do (without looking at the graphes) ? I can't use harmonic_distorsion_analyser.vi ?
Thank you.
Message 9 of 15
(7,013 Views)
The  components level output should indicate the amplitudes of the harmonics detected, including the DC level.
You need to plot really for visulization and to make sure the results do make sense.
Message 10 of 15
(7,005 Views)
