Showing results forĀ
Search instead forĀ
Did you mean:Ā
hard copy examples
i am attaching my .vi file. I want to take screen shot of Spectrum analyzer. I gave path everything, but after running code when i try to open .bmp file, i am unable to open. can anyone help me in this...
Thanks a lot..
Pallavi
(3,848 Views)
Accepted by topic author Sim5
Without having the instrument and the instrumen driver it's hard to debug or even reproduce the behaviour. But in fact I assume it could be an issue with the instrument driver. Did you allready contact the develper of it or the instruments manufacturer?
If there is a way to just read the data from the instrument, you could also present it in a graph control and export this image then as .bmp via the Export Image Method.
Christian
(3,844 Views)
I am attaching screenshot of my block diagram. I tried to contact them and acc i hv done but still unable to see the screenshot after running the vi.
Pallavi
(3,838 Views)
hello,
i got it... Thanks for help...
Pallavi
(3,823 Views)
